In my application The date dimension has two hierarchies. First one is Year -> MonthName ->Day Number Of Year. Second one is Year -> Day Number Of Year.
I test these two dimensions in the applicaiton. When I expand the first hiearchy application failed with no error but the second one is expanded properly. But these situation is happening sometimes.
I use Month name Turkish Month Name. I think error happens because of special characters (ş,ğ..). When I change the Month to English Month Name it works.
Is it a bug? Or Do I make something wrong?
Since v12.1 RTM (12.1.20121.1016) was released there were three service release versions released after. The latest's one version is 12.1.20121.2101. I hope it makes more sense now.
Regards.Plamen.
Thank you for yor reply. But I think I use lastest version. Which version I must use? Sorry, I could not understand.
Would it be possible for you to give it a try with the latest v12.1 service release version. You can look for it at https://ko.infragistics.com/my-account/keys-and-downloads
Thanks.Plamen.
I use XmlaDataSource and use version of 2012.1
Could you specify whether you use XmlaDataSource and which version of the control you work with? There was addressed similar bug for XmlaDataSource but it's alredy fixed with the latest service relase.
Plamen.
