140
how can i make only one StackBarGroup(slider) open at time
Hi..
I have some Sliders(StackBarGroup's) in a StackBar. When the user clicks on Slider, all the other slider which are open should close.(There can only be one slider open at a time).
Rgds
Sashi
  • 24671
    Hi sashibala,
     Yes you can do that by calling expand() or collapse() on the side/stack bar IG javascript object (on the client side). You only need to have a reference to the HTML DOM element (obtained by document.getElementById(), then you should do :
    var stackbar = ig.bar.getStackbar(stackbarDomElement);
    stackbar.expand() ;
    stackbar.collapse();
    Currenly this is not possible using official client-side Infragistics APIs, but in the 8.2 release there will be full-blown Client-Side Object model architecture available, which will allow you to do this. Thanks for your feedback. I hope the suggested solution helps.
    --Angel
