Hi, could anybody help in resolving the following problem?
I'm a newbie in Infragistics and really can't understand why I get the following behavior with UltraWebGrid:
I have a simple webform, put UltraWebGrid on it and created a datasource with an SqlSelectCommand retrieving data from a database. Simple 'Select * from Table where id=@id' - I setup id to get its value from a Session variable and setup a default value for it. If I browse my application it will display the proper data regarding default value of session variable.
Then I have some problems.. I want to change the session variable and refresh datagrid to display new data. I put a button and a label on a form and wrote the button OnClick Sub as simple as:
Session("A")=2 ' set new value to a session variable
SqlDataSource1.DataBind()
UltraWebGrid1.DataBind()
Label1.Text = "Rows = "+UltraWebGrid1.Rows.Count.ToString
Well, in the result, I'll still have the same rows (nothing has changed with my data in grid), the number of rows changes only if I click the button twice or more.
What is wrong? :(
Thanks!
you know how i change ultragrid mode from clickabe to not?
that canbe made? making a gri enable = false?
In case someone is experiencing a similar issue - I also had a problem with having to double click on the button that does rebinding. The solution was to set IsBound=false for the columns in the webgrid. Why is that - I have no idea.
Thanks, I've solved the proble finally
