540
Changing or Binding to xamGrid Header Text
I have an issue, that I think would be relatively straight forward, but I can't seem to make it work...
In short, I have a xamGrid, that is bound to some item source.  That source is a list of schedule data.  I simply want to change the headers to the dates based on the client's search.  So, I set them to some default like "Data1Text" through "Data7Text".  When the grid loads, I want it to change to something like "Sunday, 9/1/12" (first column header text) through "Saturday, 9/7/12" (last column header text).
I am using Template Columns.  I tried binding to the item source...to the view model... it never changes to the date.. below is a code snippet.  If that can't work, then I don't mind changing the column header text after the item source is updated...but I can't figure what event is used for that.  I am using MVVM and Prism framework, if that helps.
<ig:XamGrid HorizontalAlignment="Center" Name="xamGrdManageWeeklyPlanner" VerticalAlignment="Top"
ItemsSource="{Binding Path=WPRecords, Mode=TwoWay}" AutoGenerateColumns="False" MinWidth="890" MaxHeight="400"
SelectedCellsCollectionChanged="xamGrdManageWeeklyPlanner_SelectedCellsCollectionChanged"
SelectedRowsCollectionChanged="xamGrdManageWeeklyPlanner_SelectedRowsCollectionChanged"
MouseMove="xamGrdManageWeeklyPlanner_MouseMove" InitializeRow="xamGrdManageWeeklyPlanner_InitializeRow"
PropertyChanged="xamGrdManageWeeklyPlanner_PropertyChanged">
<ig:ContextMenuService.Manager>
<ig:ContextMenuManager>
<ig:ContextMenuManager.ContextMenu>
<ig:XamContextMenu Name="conWPMenuGrid" ItemClicked="XamContextMenu_ItemClicked" Opening="conMenuGrid_Opening">
<ig:XamMenuItem Header="Detail Manpower" />
<ig:XamMenuItem Header="Take Attendance" />
<ig:XamMenuItem Header="Modify Times" />
<ig:XamMenuItem Header="Modify Schedule" />
<ig:XamMenuItem Header="Approve Leave" />
<ig:XamMenuItem Header="Deny Leave" />
<ig:XamMenuItem Header="Modify Assignment Template" />
</ig:XamContextMenu>
</ig:ContextMenuManager.ContextMenu>
</ig:ContextMenuManager>
</ig:ContextMenuService.Manager>
<ig:XamGrid.Columns>
<ig:TemplateColumn Key="Employee" HeaderText="Employee" MaximumWidth="150">
<ig:TemplateColumn.ItemTemplate>
<DataTemplate>
<ContentPresenter Content="{Binding Employee}"/>
</DataTemplate>
</ig:TemplateColumn.ItemTemplate>
</ig:TemplateColumn>
<ig:TemplateColumn Key="Data1Text">
<DataTemplate>
<ContentPresenter Content="{Binding Data1}"/>
</DataTemplate>
<ig:TemplateColumn Key="Data2Text">
<ig:TemplateColumn.HeaderTemplate>
<DataTemplate>
<TextBlock Text="{Binding}"/>
</DataTemplate>
</ig:TemplateColumn.HeaderTemplate>
<DataTemplate>
<ContentPresenter Content="{Binding Data2}"/>
</DataTemplate>
<ig:TemplateColumn Key="Data3" HeaderText="Data3">
<DataTemplate>
<ContentPresenter Content="{Binding Data3}"/>
</DataTemplate>
<ig:TemplateColumn Key="Data4" HeaderText="Data4">
<DataTemplate>
<ContentPresenter Content="{Binding Data4}"/>
</DataTemplate>
<ig:TemplateColumn Key="Data5" HeaderText="Data5">
<DataTemplate>
<ContentPresenter Content="{Binding Data5}"/>
</DataTemplate>
<ig:TemplateColumn Key="Data6" HeaderText="Data6">
<DataTemplate>
<ContentPresenter Content="{Binding Data6}"/>
</DataTemplate>
<ig:TemplateColumn Key="Data7" HeaderText="Data7">
<DataTemplate>
<ContentPresenter Content="{Binding Data7}"/>
</DataTemplate>
</ig:XamGrid.Columns>
<ig:XamGrid.SelectionSettings>
<ig:SelectionSettings CellClickAction="SelectCell" RowSelection="None" />
</ig:XamGrid.SelectionSettings>
<ig:XamGrid.EditingSettings>
<ig:EditingSettings AllowEditing="None" IsOnCellActiveEditingEnabled="False" IsMouseActionEditingEnabled="None" IsF2EditingEnabled="False" />
</ig:XamGrid.EditingSettings>
<ig:XamGrid.FilteringSettings>
<ig:FilteringSettings AllowFiltering="FilterMenu" FilteringScope="ColumnLayout" FilterMenuSelectionListGeneration="CompleteList"></ig:FilteringSettings>
</ig:XamGrid.FilteringSettings>
</ig:XamGrid>
  • 540
    Verified Answer
    Greetings all,
    Well, I guess this is what happens when you try to code late... i figured out the fix for this today, it was, as I thought, straight forward.  I had this code in my InitializeRow method for the grid.  Which was right...except I forgot the "_count++" at the end of the foreach... ::sigh:: It is working as expected now.
    private void xamGrdManageWeeklyPlanner_InitializeRow(object sender, InitializeRowEventArgs e)
                int _count = 0;
                foreach(var c in e.Row.Columns)
                    switch (_count)
                        case 0:
                            break;
                        case 1:
                            c.HeaderText = (this.DataContext as vmSchSchedule).Data1Text;
                            break;
                        case 2:
                            c.HeaderText = (this.DataContext as vmSchSchedule).Data2Text;
                            break;
                        case 3:
                            c.HeaderText = (this.DataContext as vmSchSchedule).Data3Text;
                            break;
                        case 4:
                            c.HeaderText = (this.DataContext as vmSchSchedule).Data4Text;
                            break;
                        case 5:
                            c.HeaderText = (this.DataContext as vmSchSchedule).Data5Text;
                            break;
                        case 6:
                            c.HeaderText = (this.DataContext as vmSchSchedule).Data6Text;
                            break;
                        case 7:
                            c.HeaderText = (this.DataContext as vmSchSchedule).Data7Text;
                            break;
                        default:
                            break;
                    _count++;
