35
Infragistics Webcombo loses its style with update panel
 Am using an infragistics webcombo inside a update panel as
<asp:UpdatePanel ID="uplDesrProProjectName" runat="server" >
<ContentTemplate>
<div id="test" runat="server">
<igcmbo:WebCombo ID="ddlDestProProjectName" runat="server" SkinId = "Remove" >
<Columns>
<igtbl:UltraGridColumn BaseColumnName="ProjectId" >
</igtbl:UltraGridColumn>
<igtbl:UltraGridColumn BaseColumnName="ProjectName">
</Columns>
</igcmbo:WebCombo>
</div>
</ContentTemplate>
</asp:UpdatePanel>
 The webcombo is losing its style and not displaying properly.
The Infragistics version is Net Advantage for .NET 2007 Volume 1 CLR 2.0.
 I tried using an empty <style> tag before and after the update panel, but that also did not work.
If any of you have faced a similar problem and found a soulution, please share it.
Sapna
