We have a web application that uses 7.2 asp.net infragistics controls. These controls don't work properly in ie9. For eg: in an ultrawebgrid, the header and other rows go out of sync whenever we scroll breadth wise. I upgraded the version to 11.1, but the problem still persists in ie9. During the up-gradation, i changed the references to the new version and changed the Assembly name in Register tag in the aspx page to the correct version. Is there any other configuration change that i need to make?
Shilpi
Hello Shilpi,
If you need any further assistance with the matter, please let me know.
Hi Shilpi,
You should change the version numbers also in the web.config file. Can you tell me what version exactly you are using? The 11.1 controls should be working correctly under IE9.
