585
WebDataTree - NodeTemplates and Template event handling
Hi everyone,
I am using a WebDataTree to provide filtering options for a WebDataGrid on the same page. Therefore I need a couple of templates for the various types of filters that I've got (by text, DatePicker, DropDown etc).
I have created a few templates, but the controls inside the template are always shown in the second line of the node (screenshot and code snippet attached below). How can I achieve the controls being displayed in the same row as my expansion indicator.
Furthermore, in another template I have got a CheckBox included. I have read dozens of posts on the issue but none of them helped me in any way. The CheckedChanged-Event just won't fire server side. Maybe i missed out on s,th.
Any help is much appreciated,
Regards
<ig:WebDataTree ID="wdtFilterTree" runat="server" Height="99%" Width="99%" DataSourceID="whdsFilterTree" OnPreRender="wdtFilterTree_PreRender" SelectionType="None">
<Templates>
<ig:ItemTemplate ID="wdtFilterTreeTemplate1" runat="server" TemplateID="FilterItemTemplate">
<Template>
<asp:CheckBox ID="cbxFilterItem" runat="server" AutoPostBack="true" OnCheckedChanged="cbxFilterItem_CheckedChanged" />
<asp:Label ID="Label1" runat="server"
Text="<%# ((BDEManager.Web.Filter.FilterItemBase)((WebHierarchyData)Container.DataItem).Item).DisplayName %>" />
</Template>
</ig:ItemTemplate>
<ig:ItemTemplate ID="wdtFilterTreeTemplate2" runat="server" TemplateID="DatePickTemplate">
<Template>
<igsch:WebCalendarView ID="WebCalendarView1" runat="server" WebScheduleInfoID="wsiFilter" >
</igsch:WebCalendarView>
<igsch:WebScheduleInfo ID="wsiFilter" runat="server" />
</Template>
</ig:ItemTemplate>
</Templates>
<DataBindings>
<ig:DataTreeNodeBinding DataMember="odsAuthCaptionList_DefaultView" TextField="DisplayName" ValueField="Id" />
<ig:DataTreeNodeBinding DataMember="odsAuthItemList_DefaultView" TextField="DisplayName" ValueField="Id" />
<ig:DataTreeNodeBinding DataMember="odsDepartmentCaptionList_DefaultView" TextField="DisplayName" ValueField="Id" />
<ig:DataTreeNodeBinding DataMember="odsDepartmentItemList_DefaultView" TextField="DisplayName" ValueField="Id" />
<ig:DataTreeNodeBinding DataMember="odsStatusCaptionList_DefaultView" TextField="DisplayName" ValueField="Id" />
<ig:DataTreeNodeBinding DataMember="odsStatusItemList_DefaultView" TextField="DisplayName" ValueField="Id" />
</DataBindings>
</ig:WebDataTree>
protected void wdtFilterTree_ItemCommand(object sender, EventArgs e)
protected void cbxFilterItem_CheckedChanged(object sender, EventArgs e)
Both of these events won't fire, although I am aware that CheckBox probably is not firing ItemCommand-Event.
Below you can see the surplus space in the first line of the templated nodes:
