We have been using Infragistics and included the assemblies from a assembly folder at first.
At a later time we installed infragistics on the build server as described in the help files.
We have automated deployments using MS Webdeploy, and manual deployment of packages built with deploy targets.
When we deploy, the trial message is still apparent on the deployment target. How can we best approach working to remove the trial message ?
I hadn't heard back from you and I was wondering if you had any questions.
Please let me know if there is anything further that I can help you with.
You're going to have to be sure that you replace any of the trial dlls for any project that is still showing the trial message.
Hope that helps. Let me know if you have any questions.
