4970
how to put ConditionalFormatCollection as a cell style in App.xaml and apply it for a column in code?
I want to set up ConditionalFormatCollection  for a TextColumn in XamGrid like:
<ig:TextColumn.ConditionalFormatCollection>
    <ig:EqualToConditionalFormatRule Value="ABC">
      <ig:EqualToConditionalFormatRule.StyleToApply>
          <Style TargetType="ig:ConditionalFormattingCellControl">
                <Setter Property="Foreground" Value="Green" />
                      <Setter Property="FontWeight" Value="SemiBold" />
          </Style>
      </ig:EqualToConditionalFormatRule.StyleToApply>
   </ig:EqualToConditionalFormatRule>
   <ig:EqualToConditionalFormatRule Value="XYZ">
                <Setter Property="Foreground" Value="Red" />
          </Style>
</ig:TextColumn.ConditionalFormatCollection>
It has no problem to put in xaml in user control directly. But I want to put it in app,xaml as a cell style, and then use it in code for any XamGrid based on the data loaded. How to implement this request?
here is my testing:
1. created style and put it app.xml:
  <Style TargetType="ig:ConditionalFormattingCellControl" x:Key="ABC">
  </Style>
  <Style TargetType="ig:ConditionalFormattingCellControl" x:Key="XYZ">
  </Style>
2. in xaml for user control, the column is
<ig:XamGrid.ConditionalFormattingSettings>
        <ig:ConditionalFormattingSettings AllowConditionalFormatting="True" />
    </ig:XamGrid.ConditionalFormattingSettings>
<ig:TextColumn Key="MyColumn" >
    <ig:TextColumn.HeaderTemplate>
        <DataTemplate>
          <TextBlock Text="MyColumn" />
        </DataTemplate>
    </ig:TextColumn.HeaderTemplate>
</ig:TextColumn>
3. in code, try to apply above style:
        ConditionalFormatCollection coll = new ConditionalFormatCollection();
            coll.Add(new EqualToConditionalFormatRule()
                Value = "ABC",
                StyleToApply = Application.Current.Resources["ABC"] as Style,
                Value = "XYZ",
                StyleToApply = Application.Current.Resources["XYZ"] as Style
            // Add Rule to the UnitsInStock Column
            grid.Columns.DataColumns["MyColumn"].ConditionalFormatCollection = coll;
then run the app for testing, it is not working.  Help please. Thanks.
