I am missing something pretty basic somewhere.
I am attempting to populate controls on my .aspx from values in my business object. the controls consist of one WebNumericEdit, one WebTextEdit, and one WebCombo.
On page load, I set the WebCombo.DataSourceID = Nothing just to fire the InitializeDataSource. In the InitializeDataSource, I retrieve a dataset of data, set the datasource and databind to the combo. The combo loads the items fine.
Then I retrieve my business object (LicenseClass) and I am trying to populate the controls. The numeric edit and text edits populate just fine but I cannot figure out how to set the value of the WebCombo to the value in my object. I am trying to give the user an opportunity to edit an existing record by selecting a different item in the combo.
Can someone tell me how to set the initial value of the web combo to the value in my business object?
...Portion of Page_Load
'Trigger the loading of the combo.
licensetypeWebCombo.DataSourceID = Nothing
'Instantiate a license class object and populate the key value.
Dim MyLicenseClass As New LicenseWS.clsLicenseClass
MyLicenseClass.LicenseClassCode = Request.Params("Class")
'Ask the presentation layer to retrieve the class from the business layer.
MyPres.GetNIPRLicenseClass(MyLicenseClass)
'Populate the controls
classcodeWebNumericEdit.Text = MyLicenseClass.LicenseClassCode
nameWebTextEdit.Text = MyLicenseClass.LicenseClass
(the following two lines are just flailing attempts to set the value not meant in reality to have both in place)
licensetypeWebCombo.SelectedRow = licensetypeWebCombo.Rows.FromKey(MyLicenseClass.LicenseClassCode)
licensetypeWebCombo.DisplayValue = licensetypeWebCombo.FindByValue(MyLicenseClass.LicenseTypeCode).ToString
...WebCombo_InitializeDataSource
'Load the combobox
'Instantiate the presentation layer
Dim MyPres As New clsPresentationLogic
'Ask the presentation layer for the list of license types
MyPres.GetLicenseTypes(dsLicenseTypes)
'Set the combo datasource to the dataset
licensetypeWebCombo.DataSource = dsLicenseTypes
licensetypeWebCombo.DataBind()
licensetypeWebCombo.DataTextField = "LicenseType"
licensetypeWebCombo.DataValueField = "LicenseTypeCode"
'Clean up
MyPres = Nothing
Excellent! Happy Coding!
Thanks, Patrick!....I think I had just been staring at it way too long. It works swimmingly, now.
jc
Hello Jerry -
licensetypeWebCombo.SelectedIndex = licensetypeWebCombo.FindByValue("your LicenseTypeCode").Row.Index
I also normaly set datavaluefield and datatextfield before databind. Also the line above would go after databind.
Hope it helps,
Patrick
