How can I create a derived measure field dynamically, that calculates the distinct count of another field?
For example, take the flat table below that contains raw data depicting a list of men who went to an events and met women:
Male_Name
Event_Name
Female_Name
Jack
Concert
Ashley
Brittney
Party
Steph
Linda
Mixer
Amber
Bob
Ginger
Gail
Sophia
Chad
The following Pivot Grid shows the Event_Name as columns, Male_Name as rows and Number_Of_Girls_Met as the measure which is derived from the distinct count of Female_Names:
2
1
3
How do I make the measure field Number_Of_Girls_Met of type integer, without setting this up in the database?
Looks like something that I am looking too. I have a class Customer. How can I expose the property(Amount) of Order as a measure, if I create a Cube out of List of Customers(basically FlatDataSource).
public class Customer
string Name {get; set;}
Order CustOrder {get; set;}
public Order
string OrderNum {get; set;}
double Amount {get; set;}
Plamen, YOU ARE A GENIUS!!!
This is exactly what I need. Although I was hoping that your first suggestion would work, because it made a lot of sense. I am happy with the solution you've provided. It's given me extra things to add to the application.
Thank You!!!
I have modified the TopCountAggregator so it can follow different behaviors now. You can find a working sample attached which I hope will cover your needs.
Best regards.Plamen.
Thanks for all the help Plamen. However, that did not do anything. For the following example, I'm using this data model (obviously with a modified namespace)
http://help.infragistics.com/Help/Doc/Silverlight/2012.2/CLR4.0/html/SalesDataSample.html
I'm beginning to suspect this cannot be done with a simple xaml tag although I'm still hoping there's an easy answer. I tried attaching my solution but i've been getting a 500 server error. so here's the main xaml file:
<Grid x:Name="LayoutRoot" Background="White"> <Grid.Resources> <models:SalesDataSample x:Key="dataSample"/> <olap:FlatDataConnectionSettings x:Key="FlatDataConnectionSettings" ItemsSource="{StaticResource dataSample}" /> <olap:FlatDataSource x:Key="flatDataSource" ConnectionSettings="{StaticResource FlatDataConnectionSettings}" Cube="Sale" Rows="[Seller].[Seller]" Columns="[Product].[Product]" Measures="AmountOfSale" > <olap:FlatDataSource.CubesSettings> <olap:CubeMetadata DataTypeFullName="PivotGridSample.Models.Sale" DisplayName="Sale of the Greatest">
<!-- NOTE TO INFRAGISTICS: This is the derived measure I would like to get - A distinct count (Seller Count) of the dimension field (Seller),
: note that this measure does not exist in the model, I want to derive it from an existing dimension.
: Using your suggestions, this field does not show up on the measures tree of the data selector.
: Could it be because we need to make some kind of custom aggregator that we need to set in the "Aggregator" property? -->
<olap:DimensionMetadata SourcePropertyName="Seller"
DisplayName="Seller Count"
AggregatorType="DistinctCount"
DimensionType="Measure"/>
</olap:CubeMetadata> </olap:FlatDataSource.CubesSettings> </olap:FlatDataSource> </Grid.Resources>
<Grid.ColumnDefinitions>
<ColumnDefinition></ColumnDefinition>
<ColumnDefinition Width="Auto"></ColumnDefinition>
</Grid.ColumnDefinitions>
<ig:XamPivotGrid HorizontalAlignment="Left" Name="xamPivotGrid1" VerticalAlignment="Top" Grid.Column="0" DataSource="{StaticResource flatDataSource}"/>
<ig:Expander Grid.Column="1">
<ig:XamPivotDataSelector HorizontalAlignment="Left" Name="xamPivotDataSelector1" VerticalAlignment="Top" DataSource="{StaticResource flatDataSource}"/>
</ig:Expander>
</Grid>
</UserControl>
Hello,The cube settings should be added before items source is set because all metadata is processed when items source is set.FlatDataSource dataSource = new FlatDataSource();
dataSource.CubesSettings.Add(cubeMetadata);dataSource.ItemsSource = DatingViewModel.BoyMeetsGirlObservableCollection;
Regards.Plamen.
