I wanted to know - 1. Is Silverlight 5 client runtime is mandatory for a browser to execute applications which has used Infragistics versions 2012.1 and/or 2012.2?
2. Is it mandetory for a developer to upgrade to Silverlight 5 developer runtime, SL5 developer tools, SL5 Control toolkit to work with Infragistics versions 2012.1 and/or 2012.2?
Rohan
Hello Rohan,
Thanks again.
Hi Stefan, thanks for your reply. I got my answer. :)
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
Thank you for your post. I have been looking into it and I can say that you should have SL 5 client in order to run Silverlight applications or applications that contains Silverlight controls. Also you need Silverlight 5 developer runtime in order to create SL application. The requirements are the same as for using regular SL controls. Please let me know if this helps you or you need further assistance on this matter.
