633
How to cancel node checked client side event.
Hi!
I have a tree placed on an asp.net wizard's page. I needed the functionality that when only one node can be checked in a given hierarical level. I did this using the node checked client side event. Everything works fine. However after unchecking a node from the client side using node.setChecked(false/true)
This works fine, unless after the script unchecks a node i goto the next wizard page and then come back using the previous button.  Now the same node is shown as checked. Any idea what could be going wrong.
 Ahmad
