This happens quite randomly. Sometimes it works; sometimes it doesn't as shown on the screen shots. With the code that I'm including in this message, it doesn't work most of the time, meaning the tiles get stuck on the left as it loads, when it's supposed to spread out evenly.
When I remove all the xamcharts, lays itself out correctly 100% of the time. but that's not acceptable because we need the charts.
When I remove the xamGrid, it also works 100% of the time. That's also unacceptable because we need that grid in the application.
Figure 1. Tiles bunched up on the left (BAD)
Figure 2. Tiles spread out evenly (GOOD)
Here’s the XAML code: (Obviously, our application is more complex. I’ve simplified it as much as possible for the purpose of troubleshooting)
<UserControl x:Class="SilverlightTiles.MainPage"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
mc:Ignorable="d"
d:DesignHeight="300" d:DesignWidth="400" xmlns:ig="http://schemas.infragistics.com/xaml">
<Grid x:Name="LayoutRoot">
<ig:XamDockManager x:Name="xamDockManager" >
<ig:XamDockManager.Content>
<ig:DocumentContentHost Orientation="Vertical">
<ig:DocumentContentHost.Panes >
<ig:TabGroupPane>
<ig:ContentPane x:Name="FirstPane"
Header="First Pane"
IsActivePane="True"
IsDocumentPane="True"
AllowClose="False"
FontSize="14">
<Grid x:Name="TSActivitySummaryGrid">
<Grid.ColumnDefinitions>
<ColumnDefinition Width="300"></ColumnDefinition>
<ColumnDefinition Width="*"></ColumnDefinition>
</Grid.ColumnDefinitions>
<ig:XamGrid Name="xamGrid1"></ig:XamGrid>
<ig:XamTileManager Name="xamTileViewSummary"
VerticalAlignment="Top"
Grid.Column="1" >
<ig:XamTileManager.MaximizedModeSettings>
<ig:MaximizedModeSettings
MaximizedTileLocation="Top"
ShowAllMinimizedTiles="True"
MinimizedTileExpansionMode="AllowOne"/>
</ig:XamTileManager.MaximizedModeSettings>
<ig:XamTileManager.NormalModeSettings>
<ig:NormalModeSettings ShowAllTiles="True"
TileLayoutOrder="UseExplicitRowColumnOnTile"
MaxColumns="3"
MaxRows="2"
VerticalTileAreaAlignment="Stretch"
HorizontalTileAreaAlignment="Stretch"
MinColumns="3"
MinRows="2" />
</ig:XamTileManager.NormalModeSettings>
<ig:XamTile Header="Un"
ig:XamTileManager.Column="0"
ig:XamTileManager.Row="0">
<ig:XamDataChart x:Name="SampleChart1">
</ig:XamDataChart>
</ig:XamTile >
<ig:XamTile Header="Deux"
ig:XamTileManager.Column="1"
<ig:XamDataChart x:Name="SampleChart2">
<ig:XamTile Header="Troix"
ig:XamTileManager.Column="2"
<ig:XamDataChart x:Name="SampleChart3">
<ig:XamTile Header="Quatre"
ig:XamTileManager.Row="1">
<ig:XamDataChart x:Name="SampleChart4">
<ig:XamTile Header="Cinq"
<ig:XamDataChart x:Name="SampleChart5">
<ig:XamTile Header="Six"
<ig:XamDataChart x:Name="SampleChart6">
</ig:XamTileManager>
</Grid>
</ig:ContentPane>
</ig:TabGroupPane>
</ig:DocumentContentHost.Panes>
</ig:DocumentContentHost>
</ig:XamDockManager.Content>
</ig:XamDockManager>
</UserControl>
We have shipped out a new service release where your issue is resolved. I'd be glad to find out if you had tested it out and if it had met your requirements.
You can download the Service Releases by logging to our web site and going to Account \Keys & Downloads.
I have logged this with development under ID: 127003 and I have also created a support ticket on your behalf: CAS-104444-D2D5W4 and have linked the development issue to it, so that you can get automatically updated, when a Service Release containing the fix is available for download. You can get the new version from our website’s “My IG”, “My Keys & Downloads” tags: https://ko.infragistics.com/Membership/Default.aspx?panel=Downloads#Downloads
You can also monitor the support ticket’s progress through the “My Support Activity” tag: https://ko.infragistics.com/Membership/MySupport.aspx
