Hi everybody.
I use the 'XamMultiColumnComboEditor' and I have a problem : Sometimes the dropdown is opening in front of the combobox.How can I fix it ?This problem appears when the combobox is at the center of the page.
Best regards,Yoann.
The development issue with ID of 128321 has been fixed and it is available in the latest Service Release. You can download the Service Release by logging in our web site and then going to Account\My Keys and Downloads page.
Sincerely,
Krasimir
Developer Support Engineer
www.infragistics.com/support
Thank you for your post and the clarification on the issue. I have logged this behavior with our developers in our tracking system, with an issue ID of 128321. I have also created a support ticket on your behalf with number CAS-105215-M8S2Y7in order to link the development issue to it so that you are automatically updated when a Service Release containing your fix is available for download.
Infragistics, Inc.
Hi Krasimir,
I reproduce the bug by inserting the XamCombo in a middle of a grid, I modified the sample.
Regards.
Hello, Yoann
Thank you for your post. I have been looking into the behavior that you have described and I could not managed to reproduce it. I have created a sample application with a XamMultiColumnComboEditor in it and I have added the editor at the center of the page. When I open the drop down, it appears below the editor, as expected. I have tested the sample application, using both, the RTM and the latest service release of version 12.2, with the same result.
Please let me know if you can reproduce the same behavior with my sample application and if not, would you please modify my sample to show the issue, in order to be able to investigate what the reason for it might be?
