Hello.
I've developed my own ResourceManager for my silverlight project. Now I want to use the XamGrid localized and I don't know how can I do. Is there any way I can give the grid an xml with the resources? If not, at least setting prompt by prompt, or any other way.Thanks,Diego
Hello Diego,
It seems like that the approach I have suggested you is the only way to achive the fucntioanlity you want, but if I think of another possible solution for you I will update you.
Hello Stefan. Thanks for your reply so fast.
I have the resources in the web project, so I can't use that way from silverlight project.Is there any other way to achieve this?
Thanks,Diego
Thank you for your post. I have been looking into and I can suggest you see this link from our online documentation:
https://ko.infragistics.com/help/wpf/developers-guide-customizing-resource-strings
where it is explained how to achieve the result you want. Please let me know if this helps you or you need further assistance on this matter.
