Hi
I am a newbie with the Infragistics Reporting object.
I have Rich Text data stored in an SQL database which i need to display in a report.
I can successfully display the text by simply dragging the field onto the report designer, however it is pulling back the formatting as text instead of applying the formatting.
I have attached an example of the output.
kindest regards,
pfechner
Hi Jon,
I agree. I don't understand how you can have a reporting application but able to support rich text. A dynamic reporting solution needs to be able to hand it.
Can someone confirm if there are plans to incorporate rich text?
I am sorry to say, but "Hi! not yet" isn't good enough. this is a fairly standard feature for reporting and it would be great know WHEN it will be available. For example, this post allows rich text.
It's a basic feature, i don't understand why the first query over a year a go hasn't been sorted out yet.
oh man! I need to pull rich data from my db and link it up to a bunch of local images. Crystal Reports can sort of do it but doesn't scale images and is a memory hog.
NetAdvantage Reporting was going to be my savior!
any ideas on what else i can use?
Hi! not yet.
is there support for rich text yet?
