In My app i have one dropdown which will have page sizes as (5,10,15,20...) like that. when user changes the page size i have to change the page size of grid.
Is it possible to rebind the data in such a way user doesn't know that page size has been changed means, i am able to rebind whole grid by refreshing the whole control. But is there any way to change the data in combobox selection change event.
And i have set the dropdown to default setting based on the user selected in previous session.
Stefan,
Thanks for your solution... but no thanks. I foresaw when I wrote my post that you would come up with this solution: setting the grid's pager settings to None. Unfortunately this doesn't fit my case.
In my case I need to keep visible the pager row (in your solution when you set to No paging page row disappears), because I've put my page size combobox in the pager row, next to pager cell.
Another ideea I have is to set the page size as big as the number of records in the grid's data source, but I haven't yet tested it and there might be issues with filters.
Hello Valeriu,
I have modified the sample I sent you before, so it has the functionality you want.
I've implemented a similar solution in my application, but I wonder what would be the value for a "all records" / "no paging" behavior? Is it 0? Is it -1?
I'd like to add in the combobox another item with a value that would make the grid display all rows, like in no paging.
Thanks again.
You sample worked for me. Thanks for solving the issue.
