I need to show in a comboboxcolumn two properties of a complex object.
To achieve that I used the ValueConverter but it doesn't show me anything.
I attached a sample to show you how I do it.
Regards.
Hello Coso,
Thank you for sharing your solution.
Sincerely,ValerieDeveloper Support Engineer Infragisticswww.infragistics.com/support
Hello Valerie,
Sorry for the late answer, I found a solution by adding a partial class with my data where I put a property that represent what I need.
With this I can use a TextColumn and filter it.
Thanks for your help.
Do you have any other questions on this matter?
Valerie
The issue is that the underlying value of the cell does not contain the full text that is populated during the display using the converter. Therefore when filtering, the filter is taking the value displayed in the listbox (ex Nom + Prenom) and trying to compare this to the partial value in the cell (ex Nom). Using MVVM the idea would be that your data is represented as it is maintain in your model and then the classes can be refactored in your ViewModel to support binding to the view. This would be your best and simplest approach to resolving this issue.
Sincerely,
Thanks for your response. But I can't change my data representation, so I tried a last solution by taking one of yours (http://ko.infragistics.com/community/forums/p/59382/301863.aspx#301863). It could be a solution for me but I have some troubles with it :
- The filters are not applied correctly,
- The ClearFilters button doesn't works,
- The empty data text appears some times,
- The select all checkbox behavior doesn't works.
What am I doing wrong ?
