We recently made some CSS changes to our web app and the dev that the XamHtmlViewer creates is positioned incorrectly.
How is this calculated? Is there a way for me to adjust it?
BOb
Hello Bob,
Thank you for your feedback. If our developers determine that this is related to our control and not the Silverlight rendering system I will still update you here.
As I said above, I modified the CSS to work around it. I still feel it is a bug. However, we are dropping the Silverlight aspects of our application soon and won't be using this control much longer which is why we no longer subscribe to updates.
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
Could you please send us a sample project, where you use top=108px and the javascript to size the container, because it seems like that the issue may come from silverlight plug-in container not the control that is inside it (XamHTMLViewer). It will be greate if you also send us screenshots and more details of the result you want to achieve, so our dev. team can point you in the right direction.
Thanks Stefan. Alas we have not renewed our support/maintenance since we are converting over to Html5. So I suspect I will not be entitled to a service release? Or, do I have that wrong?
