I am using "InfragisticsSL4.Controls.Charts.XamWebChart.v10.3.dll" trying to display long labels on the X-Axis with Angle -45, the labels are not align properly and overlaping each other. tried to set width for label but it does not have width property. If we set width in the label style, still it is not fixing this issueI would like to display long labels with text trimming and full tooltip, Could you provide solution for this ?
Thank you for your post. I have been looking into it and I can say that the Labels could spread on width as wide as the column width. I can suggest you either set the Angle to 90 or use our XamDataChart control because the XamWebChart is a retired control and we no longer implement features for it.
Hope this help you.
