In XamGrid i have context menu, i am trying to stop showing the context menu on click of page numbers.
menu is coming even on changing the page numbers.
is there any fix for this ?
You can use the approach described here: http://ko.infragistics.com/community/forums/p/74396/385723.aspx#385723
Basically, you'd want to add event handler to ContextMenu's Opening event, check if the clicked object was the Pager row and cancel the operation if so. Your code should look something similar to this:
private void XamContextMenu_Opening(object sender, OpeningEventArgs e)
RowBase row = (from x in e.GetClickedElements() select x.Row).FirstOrDefault();
if (row == null || row is PagerRow)
e.Cancel = true;
Hope this helps,
