200
Implicit Data Templates with xamComboEditor
Is this supported?
I've tried without any luck.. the editor is populated with data as it should (using ObservableCollection<dynamic> as ItemsSource), but the correct DataTemplate for the relevant data type is not shown, just the default included in the control:
<UserControl.Resources>
        <DataTemplate DataType="ctl:ProductType1">
            <StackPanel Orientation="Horizontal">
                <TextBlock Text="{Binding Path=PartNumber}"/>
                <TextBlock Text=" - "/>
                <TextBlock Text="{Binding Path=RevisionName}"/>
            </StackPanel>
        </DataTemplate>
        <DataTemplate DataType="ctl:ProductType2">
            <StackPanel Orientation="Vertical">
                <TextBlock Text="{Binding Path=PartNumber}" FontWeight="Bold"/>
                <TextBlock Text="{Binding Path=Name}"/>
            </StackPanel>
        </DataTemplate>
    </UserControl.Resources>
<ig:XamComboEditor
TabIndex
="1"
x
:Name="EditorNewPartNumber"
Grid.Column
="1"
Grid.Row
="4"
Margin
="0 5 0 0"
FontFamily
="Segoe UI"
FontSize
="13"
ItemsSource
="{Binding Source={StaticResource ViewModelLocator}, Path=ViewModel.Products}"
DisplayMemberPath
="PartNumber"
SelectedItem
="{Binding Source={StaticResource ViewModelLocator}, Path=ViewModel.ProductItem, Mode=TwoWay}"
CustomValueEnteredAction
="{Binding Source={StaticResource ViewModelLocator}, Path=ViewModel.ProductEnteredAction}"
AutoComplete
="{Binding Source={StaticResource ViewModelLocator}, Path=ViewModel.IsProductEnabled}"
Visibility
="{Binding Source={StaticResource ViewModelLocator}, Path=ViewModel.IsProductRequired, Converter={StaticResource BoolToVisibilityConverter}}"
KeyUp
="EditorNewPartNumber_KeyUp"> </ig:XamComboEditor>
  • 138253
  • 138253
    Thank you for your post. I have been looking into it and I can say that because of the XamComboEditor’s DisplayMemberPath a default ItemsTemplate is created. Even if you don’t set it, it will have a default value set to the ItemsSource’s first Property, so I can suggest you define an ItemTempalte like this:
    <ig:XamComboEditor.ItemTemplate>
        <DataTemplate>
            <ContentControl Content="{Binding}"/>
        </DataTemplate>
    </ig:XamComboEditor.ItemTemplate>
    so the implicit DataTemplates could work. Please let me know if this helps you or you need further assistance on this matter.
