Do you have a code sample of how to fill a combox in the report viewer with items from a parameter with a Dynamic Values List in an infragistics report?
I have tried it in several ways, but can't get it to work.
Thank you very much for your help.
Greetings,
Geert De Vylder
Hi Geert,
I've logged your request for exposing the available parameter data in the report viewer as a new product idea and sent it directly to our product management team. Our product team chooses new product ideas for development based on popular feedback from our customer base. Infragistics continues to monitor application development for all of our products, so as trends appear in requested features, we can plan accordingly.
We value your input, and our philosophy is to enhance our toolset based on customer feedback. If your feature is chosen for development, you will be notified at that time. Your reference number for this product idea is PI13010145.
If you would like to follow up on your product idea at a later point, you may contact Developer Support management via email. Please include the reference number of your product idea in the subject and body of your email message. You can reach Developer Support management through the following email address: dsmanager@infragistics.com
Thank you for your request.
Hi Leo,
Thank you for your answer.
I'm anxiously waiting for the 12.2 SR.
Is there also a possibility to expose the available parameter data in the report viewer in a next release? This would save a lot of coding when you work with external controls. This because the queries are already defined in the report designer.
Geert
You hit a bug. It will be fixed in the next 12.2 SR, which should be out soon. In the meantime, the only workaround would be to remove all dependencies between parameters.
Best,
Leo
For those external comboboxes I'm getting the data myself from the DB in the code behind and binding it to the comboboxes. But how do you return this to the parameters defined in the report so the report can work with it?
When I run the solution and select the desired items in the 2 comboboxes on the window Report_Script_Results.xaml and click on the button. I do get the error "Infragistics.Controls.Reports.ReportViewerException: Parameter Script currently depends on another parameter. It cannot be specified in parameter bindings."
I do enclose the solution.
Thank you for your help.
Thank you for your answer. It does answer my question but not our expectations. Because the report viewer does not expose the available parameter data it reduces the flexibility of the report viewer tremendously.
We need to be able to do more with those parameters because the parameters influence the results of the queries used in the reports. We use controls outside the report viewer to have more flexibility which we need to generate reports.
Would it be possible to expose the available parameter data in the report viewer in a next version?
