Is there a way to disable the editors from changing the value when pressing the up or down arrow keys?
Don
To disable spin on arrow keys can be done using property SpinButtons.SpinOnArrowKeys=false. In this case keydown event is not processed (and not canceled). I am not sure if grid will be able to intercept those up/down arrows and do its default actions. It should be tested for a particular application (and browser).
The WebCurrencyEdit and the WebNumericEdit have a spin client-side event - you can cancel it
function WebCurrencyEdit1_Spin(oEdit, delta, oEvent){ //Add code to handle your event here. oEvent.cancel = true;}
