45
problem with column sort on webgrid
I have a web grid which gets its data source from a user generated sql query. When they sort their results in a datagrid, it causes an error when they try to export the grid.  The error is "Object reference not set to an instance of an object" when the webgrid tries to databind();  Why does this err out at this point? Does the webgrid loses its datasource when it is sorted?  The original data bind works fine, it only errs out after a user has sorted the webgrid. I don't understand what casues this error. Please let me know any information you have on this.
