845
NullReferenceException from xamGrid in a child window
We are displaying a xamGrid in a child window and populating it in response to a event from another part of the application.
We have just started getting the following unhandled exception:
Handling ID = 00000000-0000-0000-0000-000000000000
An exception of type 'System.NullReferenceException' occurred and was caught.
01/30/2013 14:15:38
Type : System.NullReferenceException, mscorlib, Version=5.0.5.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e
Message : Object reference not set to an instance of an object.
Data : System.Collections.ListDictionaryInternal
Stack Trace : at Infragistics.Controls.Grids.Primitives.RowsPanel.ResetRows(Boolean releaseAll)
at Infragistics.Controls.Grids.Primitives.RowsPanel.<>c__DisplayClass2.<ResetRows>b__0()
Additional Info:
TimeStamp : 30/01/2013 14:15:38
FullName : Microsoft.Practices.EnterpriseLibrary.ExceptionHandling.Silverlight, Version=5.0.505.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
AppDomainName : Silverlight AppDomain
Unfortunately we can't split out this part of the application to get a repeatable case, so all we are after is a guide to where we should be looking to track this down and fix the problem.
We are using version 11.2.20112.2178.
With the previous version we didn't have this problem.
