How do I align an item in a XamMenu menu so that some item XamMenuItems are aligned to the left while others are right aligned?
Perhaps this mock up might help explain better. I want the global settings menu to be right justified:
Hello Mike,
Thank you for contacting our community.
In order to set different alignment to the menu items you could define a template for the menu. This approach had been discussed in this forum thread: https://ko.infragistics.com/community/forums/f/ultimate-ui-for-wpf/46631/alignment-of-menuitems. As the thread is for WPF I created a sample project in Silverlight using the same template and attached it here.
Please feel free to let me know if you have any question on the matter.
Exactly what I needed. Thank you for the prompt reply!
Thank you for your feedback. I am glad that this helped you and I believe that other community members may benefit from this as well.
