523
Dynamic SQL reporting
I have a number of reports already finished, all of them were constructed with the visual editor and SQL. But there is a change we need to do to all of our reports, the tables from installation to installation changes its schema so, the sql doesn't work and there is an error in the report viewer. How can we reconstruct the sql with the correct schema and asign it to the report again in runtime? Thanks in advance for the help.
  • 550
    Hi Alejandro,
    If you want to change the datasource or query but the result of it has the same structure (the fields are the same), you can use a runtime datasource provider.
    If the result of the query has different fields, or types, you have to update the report definition to the new datasource structure.
    hope it helps,
    Simon
