459
save changes on exiting the application
how can i prevent the user to close the webapplication (x in internet explorer) without saving the changes in the ultrawebgrid?
elke
  • 508
    I got it. It can be done in the following way. The key is updating the readyState flag to false in AfterExitEditModeHandler.
    var readyState = true;
    window.onbeforeunload = checkProgressState;
    function checkProgressState(){
    if (!readyState){
    message = "WARNING: Your data is not saved, if you choose to exit your information may be lost.";
    return message;
    else
    readyState = true;
    function HandleExitEditMode(gridID, cellID) {
    readyState = false;
    If you want this alert to be suppressed in SaveButtonClick, then OnClientClick of that button, update the readyState variable to true.
  • 508
    Hey,
    I am also in the same situation. I need to prompt/save the grid data before exiting. Any clues on how to do it?
  • 100
     try it, but it only worked in IE:
    <html>
    <head>
    <body  onBeforeUnLoad="clean_exit(this)"  >
    something else........
    <script language="JavaScript">
    var changes=false;
    var problems=false;
    function clean_exit( src ){
          verify();
          if (problems){
                alert ("problems: " + problems);
                // the verify routine reports problems, don't allow an exit or reloading of the page
          }else{
                // no problems, so continue
                if(changes){
                      if (!confirm("You have made changes.  Click OK to save, or cancel to continue without saving")){
                            return false;
                      }else{
                            //do something
                            return true;
                      }  // end of confirm
                } // end of changes
          }// end of verify
    function changed(){
          changes=true;
    function verify(){
          var problems=false;
          with (Entry) {
                if (LastName.value == "") {
                      problems=true;
                      return false;
          changes=false;
          return true;
    </script>
    </body>
    </html>
