425
DatePicker get set in WebGrid RowEditTemplate
I am using a webgrid with RowEditTemplate as follows
<ClientBindings>
<ig:RowEditingClientBinding ColumnKey="DataConteúdo" ControlID="WebDatePickerDataConteudo"
GetValueJavaScript="$get({ClientID}).value" SetValueJavaScript="$get({ClientID}).value={value}" />
<ig:RowEditingClientBinding ColumnKey="ConteúdoDesenvolvido" ControlID="controlConteudo"
GetValueJavaScript="$get({ClientID}).value" SetValueJavaScript="$get({ClientID}).value={value}"/>
</ClientBindings>
<RowEditingClientEvents TemplateClosing="onTemplateClosing" />
I am using a javascript function as follows I have found in the forum
function onTemplateClosing(sender, args) {
var ret = sender.get_behaviors().get_editingCore().get_behaviors().get_rowEditingTemplate();
var colKey = "DataConteúdo";
var binding = ret._bindings._getObjectByAdr(colKey);
var datePicker = $find(binding.get_clientID());
var dateVal = datePicker.get_value();
It's not setting the Date column in the WebGrid with the DatePicker value! Can you please tell me what is going wrong?
Can you provide me a javascript function to get the Date field in the grid and set the DatePicker in the RowEditTemplate?
I have search the forum and the web and I think that you could provide this as a sample. I think that using RowEditTemplate is very good with IG controls!!
Thanks in advance!
Edson
