I have 2 user control with exactly same xamgrid setting like:
<XamGrid x:Name="mygrid" ItemsSource="{Binding DataList,Mode=TwoWay}" CellClicked="mygrid_CellClicked" RowSelectorClicked="mygrid_RowSelectorClicked" CellDoubleClicked="mygrid_CellDoubleClicked">.... </XamGrid>
one is fine, but one is not working properly:
CellDoubleClicked not fired up at first double click on a row. Need to click on the row firstly, then double-click on the row again, then CellDoubleClicked will be fired.
Can't figure it out. Help please.
Thank you for your post. It is very strange behavior and I cannot reproduce it on my side. Is it possible to attach a sample application with your user control which double click event is not working as expected or with the both of them in order to investigate this issue ?
