When I turn set StationaryMargins to Header, I'm getting a horizontal scrollbar which I don't need. It looks like it is compensating for the width of the vertical scrollbar.
Is there anyway to not show the horizontal scrollbar when using stationarymargins?
I'm using 2007.3 with hotfix 1049
The perfect solution to my problem:
The above gets rid of the Horizontal scrollbar. I don't need it because all my columns have fixed width
I believe this could be related to the following forum thread (there are some workarounds suggested there)
http://forums.infragistics.com/forums/p/863/11252.aspx#11252
If this does not help, I think the best solution is to have this reported to Developer Support via this link - chances are, they will be aware of some solution or log this as a bug to be fixed in one of our subsequent hotfixes
http://ko.infragistics.com/gethelp/default.aspx
Never figured it out.
I get the same behaviour too!
I presume it is some sort of property value combination that can get around this problem.
Any ideas?
