260
UltraWebGrid, select row to select a checkbox
With Version 11.1, how can I allow UltraWebGrid row selection to put or clear checkbox on the selected row?
I'm looking for behavior similar to "label for" on a checkbox, so that when a row is selected, it will give or clear checkbox in a given row.  Here is the column markup.
 <Columns>
<igtbl:UltraGridColumn Key="ColID" Hidden="True" DataType="System.Int32" BaseColumnName="ColID">
<Footer Key="ColID"></Footer>
<Header Key="ColID"></Header>
</igtbl:UltraGridColumn>
<igtbl:UltraGridColumn Key="ColSelect" Width="30px" Type="CheckBox" DataType="System.Boolean" BaseColumnName="ColSelect"
AllowUpdate="Yes">
<Footer Key="ColSelect">
<RowLayoutColumnInfo OriginX="1"></RowLayoutColumnInfo>
</Footer>
<Header Key="ColSelect">
</Header>
<igtbl:UltraGridColumn Key="ColValue" Hidden="True" BaseColumnName="ColValue">
<Footer Key="ColValue">
<RowLayoutColumnInfo OriginX="2"></RowLayoutColumnInfo>
</Footer>
<Header Key="ColValue">
</Header>
<igtbl:UltraGridColumn Key="ColDisplay" Width="100%" BaseColumnName="ColDisplay">
<Footer Key="ColDisplay">
<RowLayoutColumnInfo OriginX="3"></RowLayoutColumnInfo>
</Footer>
<Header Key="ColDisplay">
</Header>
</Columns>
Thanks.
  • 48586
    Hello, ­­­­­
    I am just checking about the progress of this issue. Let me know If you need my further assistance on this  issue?
  • 48586
    What you could do in your case is to add ClientSide event for CellClick for example, and to use following JS in order to change cell value:
    function UltraWebGrid1_CellClickHandler(gridName, cellId, button){
             //Add code to handle your event here.
             //Current clicked cell
           var cell = igtbl_getCellById(cellId);
           var boolCell = cell.Row.getCell(1);
           boolCell.setValue(!boolCell.getValue());
