230
WebGrid (DataRelation) & Grouping, sample code included
Here is a sample page I wrote binding a DataSet with a DataRelation to the WebGrid (producing a hierarchical grid).  The issue is that when you run this sample, drag row_id of band 0 to the group by row, no longer are you able to expand all the way out without the grid reloading itself.
Here are the steps:
1) Group by row_id of band 0.
2) Expand using the first + button.
3) Expand using the second + button.
As soon as step 3 is attempted, the grid instead of displaying the contents goes back to results of step 1.
Where am I going wrong?
CODE:
<%@ Page Language="VB" AutoEventWireup="false" CodeFile="test.aspx.vb" Inherits="test" %>
<%@ Register TagPrefix="igmisc" Namespace="Infragistics.WebUI.Misc" Assembly="Infragistics2.WebUI.Misc.v7.2, Version=7.2.20072.61, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" %>
<%@ Register TagPrefix="igtbl" Namespace="Infragistics.WebUI.UltraWebGrid" Assembly="Infragistics2.WebUI.UltraWebGrid.v7.2, Version=7.2.20072.61, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" >
<head runat="server">
    <title>Untitled Page</title>
    <link href="StyleSheet.css" rel="stylesheet" type="text/css" />
</head>
<body>
    <form id="form1" runat="server">
        <p>
        <igtbl:ultrawebgrid id="UltraWebGrid1" runat="server" Browser="Xml">
            <DisplayLayout RowSelectorsDefault="No"  Name="UltraWebGrid1" CellSpacingDefault="1" CellPaddingDefault="3" CellClickActionDefault="CellSelect" SelectTypeCellDefault="Extended" AllowSortingDefault="OnClient" HeaderClickActionDefault="SortSingle" ViewType="OutlookGroupBy" LoadOnDemand="Xml">
                <RowStyleDefault CssClass="GridRow">
                </RowStyleDefault>
                <HeaderStyleDefault CssClass="GridHeader">
                </HeaderStyleDefault>
                <RowAlternateStyleDefault CssClass="GridAlternatingRow">
                </RowAlternateStyleDefault>
                <GroupByBox>
                   <BoxStyle CssClass="GridHeader"></BoxStyle>
                </GroupByBox>
                <Pager Alignment="Left" PagerAppearance="Both">
                    <PagerStyle CssClass="Pager" />
                </Pager>
            </DisplayLayout>
            <Bands >
                <igtbl:UltraGridBand>
                </igtbl:UltraGridBand>
            </Bands>
        </igtbl:ultrawebgrid>
    </p>
    </form>
</body>
</html>
Imports Infragistics.WebUI.UltraWebGrid
Imports System.Drawing
Imports System.Data
Partial Class test
    Inherits System.Web.UI.Page
    Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
        If Not IsPostBack Then
            BindGrid()
        End If
    End Sub
    Private Sub BindGrid()
        Dim table1 As New DataTable
        Dim table2 As New DataTable
        Dim myDataSet As New DataSet
        Dim tmpRow As DataRow
        Try
            With table1
                .Columns.Add("row_id", GetType(Integer))
                .Columns.Add("descr", GetType(String))
            End With
            With table2
            End With
            For i As Integer = 0 To 200
                tmpRow = table1.NewRow
                tmpRow("row_id") = i
                tmpRow("descr") = "Band 0 - Row " & i.ToString
                table1.Rows.Add(tmpRow)
            Next
                tmpRow = table2.NewRow
                tmpRow("descr") = "Band 1 - Row " & i.ToString & " item 1"
                table2.Rows.Add(tmpRow)
                tmpRow("descr") = "Band 1 - Row " & i.ToString & " item 2"
            Next
            myDataSet.Tables.Add(table1)
            myDataSet.Tables.Add(table2)
            Dim rel1 As New DataRelation("rel1", table1.Columns("row_id"), table2.Columns("row_id"))
            myDataSet.Relations.Add(rel1)
            ViewState("myDataSet") = myDataSet
        Catch ex As Exception
            Response.Write(ex.Message)
        End Try
    End Sub
    Protected Sub UltraWebGrid1_InitializeDataSource(ByVal sender As Object, ByVal e As Infragistics.WebUI.UltraWebGrid.UltraGridEventArgs) Handles UltraWebGrid1.InitializeDataSource
        UltraWebGrid1.DataSource = ViewState("myDataSet")
        UltraWebGrid1.DataBind()
    End Sub
    Protected Sub UltraWebGrid1_InitializeLayout(ByVal sender As Object, ByVal e As Infragistics.WebUI.UltraWebGrid.LayoutEventArgs) Handles UltraWebGrid1.InitializeLayout
        e.Layout.ActivationObject.BorderStyle = BorderStyle.None
        e.Layout.HeaderStyleDefault.Wrap = True
        e.Layout.HeaderStyleDefault.Cursor = Infragistics.WebUI.Shared.Cursors.Hand
        ' turn on paging
        e.Layout.Pager.AllowPaging = True
        ' set up the page size
        e.Layout.Pager.PageSize = 100
        e.Layout.RowsRange = 100
        '''''''''''''''BAND 0''''''''''''''''''''''''''''''''''''''''''''''''
        With e.Layout.Bands(0).Columns.FromKey("row_id")
            .Header.Caption = "Row ID"
            .CellStyle.HorizontalAlign = HorizontalAlign.Right
            .SelectedCellStyle.BackColor = Color.LightGreen
            .Width = Unit.Pixel(3)
        End With
        With e.Layout.Bands(0).Columns.FromKey("descr")
            .Header.Caption = "Description"
            .CellStyle.HorizontalAlign = HorizontalAlign.Left
            .Width = Unit.Pixel(192)
        End With
        '''''''''''''''BAND 1''''''''''''''''''''''''''''''''''''''''''''''''
        With e.Layout.Bands(1).Columns.FromKey("row_id")
        End With
        With e.Layout.Bands(1).Columns.FromKey("descr")
        End With
    End Sub
End Class
