I am looking to get some details about a report programmatically, like the different report sections and their column sets. I am looking at some .igr files for some reports I wrote and they do appear to be XML-serialized objects. Does the NetAdvantage API provide a way to query the report definition to get details of a report?
Thanks.
I see -- ok thanks for the quick response. It doesn't look bad at all to work with using linq, but if I'm going to do that I'll at least write some wrapper classes.
Hi Jerry,
Unfortunately, there is no native API to query the report definition, you would have to consume the XML via LINQ to XML or other similar APIs.
Regards,Héctor
