I'm using Visual studio 2010 with Infragistics 10.3.20103.2217 version dll's. Testing my project in IE9.I have Hirearichal grid , every row has a child row. when I try to update any cell in the child row it is not taking the updating value. Same code works in IE8 with infragistics 8.3 versison dll's. Please suggest what needs to be changed or upgraded. This is issue is in Ultrawebgrid
yes it's resolved by upgrading the script files
Hello Usha,
Were you able to resolve the issue?
How are you updating the child row? Are you doing in the UI or from code behind? If in the code behind in which event are you trying to update it.
Can you share your code or a sample which I can use to reproduce the issue?
I am currently looking in to this issue. I will update you by the end of the day tomorrow with the progress.
