When using GroupColumns in XamGrid I am unable to select multiple cells using mouse drag. I believe I have set the correct properties since the moment I remove the group columns the drag selection works immediately.
The following code reproduces this:
Xaml:
In the example you will find that it is possible to drag select the non grouped column but not grouped columns. Removing the columns from the GroupColumn will make them work however.
Does anyone have any ideas on how to drag select with GroupColumns on XamGrid?
Note: I am using the WPF version - not sure if there is a difference but I couldn't find XamGrid category in the WPF forum.
This issue has been resolved in the latest service release. To download the update head on over to https://ko.infragistics.com/my-account/keys-and-downloads/
No, unfortunately there is no easy way to work around this issue.
Hi Nikolay,
Thanks very much for the fast response and fix.
Can you see any work around for this in the mean time? As that might save us from having to redo a lot of work using another grid for now.
I was able to reproduce the problem and I logged it into our system (CaseNumber - CAS-115118-H6Y1M4, internal id 140895).
The fix will be available in the next service release.
