180
SelectedItem Not retaining
I am using v8.1 in an ASP.Net app (2.0) and can not get the Selected Item to retain between postbacks to the server.  It may be that I am just missing something as Asp.Net development is not my strength, but is there something special I have to do?  If I click on an Item, I handle the event on the server and can get the clicked item from the event, but when the page is rendered again, the item is no longer selected.
  • 10880
    The item should stay selected as long as your not making use of the TargetUrl of the item.
    I tested with the following code and did not have any issues:
    Default.aspx
    <iglbar:UltraWebListbar ID="UltraWebListbar1" runat="server" OnItemClicked="UltraWebListbar1_ItemClicked"
                ViewType="ExplorerBar">
                <DefaultItemSelectedStyle BackColor="#FFC0C0">
                </DefaultItemSelectedStyle>
                <Groups>
                    <iglbar:Group Text="Group" TextAlign="Left">
                        <Labels Collapsed="" Expanded="" Selected="" />
                        <Items>
                            <iglbar:Item Text="Item">
                                <Labels Selected="" />
                            </iglbar:Item>
                            </iglbar:Item>
                        </Items>
                    </iglbar:Group>
                </Groups>
            </iglbar:UltraWebListbar>
    Default.aspx.cs
     protected void UltraWebListbar1_ItemClicked(object sender, Infragistics.WebUI.UltraWebListbar.WebListbarItemEvent e)
