70
How can i change Row Style on mouseover
I have a requirement where i need ot change the Row style on mouseover please help in addition MouseOutHandler never gets fired for soem reason
part of my displayLayout has following tag to catch these 2 events and below is the  Javascript code woth the functions
<ClientSideEvents
MouseOverHandler="uwgFixedAsset_MouseOverHandler"
MouseOutHandler="uwgFixedAsset_MouseOutHandler">
</ClientSideEvents>
<script type="text/javascript" language="javascript"><!--function uwgFixedAsset_MouseOverHandler(gridName, id, objectType)
// Check if the object type is a cell
if (objectType == 0)
// Get the cell that has the checkbox image
var checkBoxCell = igtbl_getCellById(id);
// Get the cell that has the check state value
var thisRow = checkBoxCell.getRow();
// Change style
thisRow.style.backgroundColor = 'LightYellow';
function uwgFixedAsset_MouseOutHandler(gridName, id, objectType)
var oCell = igtbl_getCellById(id);
// Change style
thisRow.style.backgroundColor = 'Blue';
--></script>
  • 480
    I've tested here and I think that I know how to solve your problem....
    you're probably setting the grid DisplayLayout.RowStyleDefault.BackColor = anyValue.
    When you do that, the grid inserts the formatting in the cells.....and when you change the row background by javascript, the cells <td> overlaps the row <tr> colors....
    To solve that :
    1 - You can set the row background color in a css class, setting the property in the display layout mergeStyles to false. That will not applie the style in the cell, just in the row...
    2 - You can not set the value of  DisplayLayout.RowStyleDefault.BackColor and that is it....
    3 - you can change each cell of the row in your function...
  • 480
    just one thing, you're setting the wrong property....the right is:
    thisRow.Element.style.backgroundColor = "Blue"
     maybe it's it...
