Hi
I'm using Ingfragistics 2012.1 in with Silverlight5. Recently i updated my Infragistics and accordingly i updated my Project references using Infragistics Version Utility 20212.1. So now my references version is 12.1.20121.2271 and RuntimeVersione us 4.0.30319
Now i've a problem with XamNumericEditor wchich Value property is in Binding and is not updating at all. I created and attached a sample project, in which there is a ChildWindow containig a TextBox and XamNumeric, both binding to the same source but only TextBox is updating.
Before updating the project's refences i didn't have this problem. My project is already deployed and i need to update my client with new version but with this issue i can't.
So please,i need updates urgently.
Download sample project here: https://dl.dropboxusercontent.com/u/98843090/NumericEditorErrorSL5.zip
Thank you very much
Thank you for your post. I have been looking into it and the sample you have provided and I can suggest you use XamNumericInput instead of XamNumericEditor, since it is a retired control in SL and we no longer provide fixes for it.
Hope this helps you.
