I use pivot grid without XamPivotDataSelector (Columns, Rows and Measures values are hardcoded). How to forbid deletion the pivot items (rows, columns, measures) from header areas? The way like ((DataSourceBase)pivotGrid.DataSource).AreaFieldSettings.AllowRowsEditing = false is not appropriate, because it is needed to reorder the columns using drag'n'drop.
Hi Stefan,
Thank you very much, I have posted my question in this thread with the title""License Information for this component not found" message for some controls like ssoption,sscheck,ssactivetoolbars..etc", it will be great you help for my problem.
Thanks in advance.
Regards
Balajirao
Hello Belajirao,
You chould navigate to the section you want to post your question in and click on the "Write a new Post" just below the Search bar. If you want ot post in the XamPivotGrid section you can use this link:
http://ko.infragistics.com/community/forums/401.aspx
Hope this helps you.
Hi, I want to post a question and I don't know how...can you please suggest me how to do that ....?
Hello Ilya,
Thanks again.
Hello Stefan,
Your solution is appropriate for us. Thanks a lot.
Sincerely, Ilya
