105
Export error on azure deployed MVC application
my product name is NetAdvantage Ultimate 2013 Vol. 1
I have a similar problem than http://ko.infragistics.com/community/forums/t/79908.aspx
By using HTML5 Report Viewer on azure website (MVC4), report exporting is not working,
on my development environment it works fine but once deployed to Azure it doesn't (the report viewer work correctly but not the export buttons).
The error message is :
An error occurred while exporting the report. Object reference not set to an instance of an object.
In web.config I use the following parameters :
<system.webServer>
<validation validateIntegratedModeConfiguration="false" />
<handlers>
<add name="IgReportingResourcesHandler" verb="*" path="*.igrResource" type="Infragistics.Reports.Server.ResourcesHandler, InfragisticsWPF4.Reports.Server.v13.1" />
</handlers>
<modules>
<add name="ReportProcessorServiceModule" type="Infragistics.Reports.Server.ReportProcessorServiceModule, InfragisticsWPF4.Reports.Server.v13.1" />
</modules>
</system.webServer>
and in global.asax.cs
routes.Ignore("{*allReportingResources}", new { allReportingResources = @".*\.igrResource(/.*)?" });
I use the following code on the viewpage :
<div id="report"></div>
$.ig.loader({
scriptPath: "/scripts/Infragistic/scripts/",
cssPath: "/scripts/Infragistic/css/",
resources: "igReportViewer"
$.ig.loader(function () {
$("#report").igReportViewer({
height: 600,
locale: 'fr',
pageFit: "fitToPage",
renderSettings: {
definitionUri: "avitax-total;component/Ventes.igr",
serviceEndpointUri: "/ReportService.svc/ajaxAddress/"
</script>
The dll deployed to azure website bin folder :
Infragistics.Web.Mvc.Documents.Reports, Version=13.1.20131.2103,
Infragistics45.WebUI.Documents.Reports.v13.1, Version=13.1.20131.2045,
InfragisticsWPF4.Controls.Reports.v13.1
InfragisticsWPF4.Models.Data.v13.1
InfragisticsWPF4.Models.Presentation.v13.1
InfragisticsWPF4.Reporting.v13.1, Version=13.1.20131.2073,
InfragisticsWPF4.Reports.Client.v13.1
InfragisticsWPF4.Reports.Controls.Charts.XamDataChart.v13.1
InfragisticsWPF4.Reports.Controls.Common.v13.1
InfragisticsWPF4.Reports.Controls.DataVisualization.v13.1
InfragisticsWPF4.Reports.Excel.v13.1
InfragisticsWPF4.Reports.Pdf.v13.1
InfragisticsWPF4.Reports.v13.1
InfragisticsWPF4.v13.1
May be some infragistics reference is missing on my deployment ?
Thanks for your help,
Regards
