Hi,By Using IGR and Service we can able to see the Report in Report Viewer.
var serviceEndpoint= "/samplesbrowser/Services/ReportService.svc/ajaxAddress/";
renderSettings: { definitionUri: "Infragistics.Web.ReportLibrary;component/ReportDesigns/CustomersList.igr", serviceEndpointUri: serviceEndpoint },
Is there any other way to show the Report in Report Viewer without using Service?
Tamilmani Mohan
hey
Let me know if you need any additional help. Thanks
Angel
No, the serviceEndpointUri is required. The HTML5 ReportViewer needs the backend part (service) because the service code pulls all the data from the various sources.
Hope it helps. Thanks,
