Let’s suppose that we have a Silverlight application like the following one: <Grid x:Name="LayoutRoot"> <Grid.RowDefinitions> <RowDefinition Height="50" /> <RowDefinition Height="*" /> </Grid.RowDefinitions> <!--Grid.Row="0" The Main App Menu--> <Canvas Grid.Row="1" x:Name="viewContainer"> <!--Some controls--> <ig:XamSpellChecker x:Name="customSpellChecker"> <ig:XamSpellChecker.DialogSettings> <ig:XamSpellCheckerDialogSettings /> </ig:XamSpellChecker.DialogSettings> <ig:XamSpellChecker.SpellCheckTargets> <Binding ElementName="txtATextBoxIn_viewContainer" Path="Text" Mode="TwoWay"/> </ig:XamSpellChecker.SpellCheckTargets> </ig:XamSpellChecker> </Canvas> </Grid>Is it possible to set the XamSpellChecker so its parent panel is viewContainer? The idea is that the spell checker does not float outside the parent panel. It looks like there is a ChildWindow that hosts the spell checker, which allows it to float in the whole Silverlight application window.Thank you,Juan Aquino
Hello Juan,
Thank you for the feedback. Please do not hesitate to contact us if you have any questions.
It works fine. It is required to update to Silverlight 2013 Vol. 1.
Thank you,
I am just checking your progress on the issue. Please do not hesitate to let me know if you have any further questions.
Hi Juan,
You can restrict the XamSpellChecker from floating over the whole SL app by setting the RestrictInContainer property of the SpellCheckDialog:
customSpellChecker.SpellCheckDialog.RestrictInContainer = true;
Hope this helps,
