120
Disable context menu?
How can one disable the xamGantt control's context menu? We would like to prevent this menu from showing up at all..
Thanks for any info,
-Lyndon
  • 54937
    Verified Answer
    The context menus are defined by the ContextMenuProvider of the xamGantt. If you want to override a context menu you would set the ContextMenuProvider to a new instance of a GanttContextMenuProvider and then set the ResourceOverrides to a ResourceDictionary that defines the xamContextMenu instance(s) for each area (defined by the items of the GanttContextMenuArea enumeration) where the x:Key is the name of the enumeration item whose area is to be overridden. If a xamContextMenu has no items then no context menu will be displayed. So if you wanted to prevent all the context menus you might do something like:
    <ig:XamGantt>
        <ig:XamGantt.ContextMenuProvider>
            <ig:GanttContextMenuProvider>
                <ig:GanttContextMenuProvider.ResourceOverrides>
                    <ResourceDictionary>
                        <ig:XamContextMenu x:Key="ColumnHeader" />
                        <ig:XamContextMenu x:Key="Row" />
                        <ig:XamContextMenu x:Key="RowSelectorHeader" />
                        <ig:XamContextMenu x:Key="Cell" />
                        <ig:XamContextMenu x:Key="Task" />
                        <ig:XamContextMenu x:Key="TaskDependency" />
                        <ig:XamContextMenu x:Key="Grid" />
                    </ResourceDictionary>
                </ig:GanttContextMenuProvider.ResourceOverrides>
            </ig:GanttContextMenuProvider>
        </ig:XamGantt.ContextMenuProvider>
    </ig:XamGantt>
