Hi
I'm using pivot table, and I need use a calculated measure.
I'm implemented with CalculatedMeasureViewModel, like example: http://ko.infragistics.com/help/topic/34854EEA-2767-4DB9-901F-C9208D832836
But using calculated measure, no measures was shown, but, when removed manually, the "normals" measures turn visible.
Anybody have a complete example?
My Example is in attached.
Find for "// HERE THE CALCULATED MEASURE, WITH A SIMPLE EXPRESSION"
Hi Cassio,
Can you please look at this forum post: http://ko.infragistics.com/community/forums/t/81244.aspx
Here is posted a solution that creates a percentage measure aggregator called "CompoundMeasuresSample.zip". If this is not helpful for you can you please attached a picture of what you are trying to achieve.
M.Yovchev
Hi Yovchev.
Exists some way to reproduce calculated measure with FlatDataSource?
Currently, I calculate in the server side, and send the calculated answer to Pivot Grid.
But, my problem is expressions like percents (Item/Total*100). The total cells presents the sum, and not the percent.
Cássio Almeron
As I can see in your example you are using FlatDataSource. In the topic, you mentioned in your post, is written that Calculated Measures feature works only with XMLA data source.
