I have just download the Iguana UI but I am facing a problem to run the sample projects.
I imported the project on Eclipse but when running the project I received a confusing message "error opening trace file: No such file or directory (2)"
Could not find class 'com.iguanaui.controls.DataChart', referenced from method com.iguanaui.mixedseries.MixedSeriesActivity.createChart.
(Please the attached documents for more information)
I checked that the .jar files are attached and the android version.
Is it a problem of permission or something I have missed?
I eager to start using those tools.
I am just checking about the progress of this issue. Let me know If you need any further assistance on this issue?
Thank you for your feedback. Please keep us updated about the progress of this matter.
Thank you for your loyalty to Infragistics.
I will check them and let you know. I am very happy from your support and that's why I am so loyal to your products.
Have a nice day
Here is the other samples. Please import the attached samples as “Existing Android Code Into Workspace”. Then first run your emulator or device then clean desired sample and rebuild it, after that run it as “Android Application” .
I hope that this will helps you.
yes. it works but is exactly the same as the one i have downloaded. I cant not run the other samples can you please send them to me.
thanks a lot
