This is a weird error client is facing on production server. When they try to export the grid data (around 20,000 records paged in set of 100s), it times out with System.OutOfMemoryException. Would you know of any known issues with the max records that grid can export.
We are using UltraWebGridExcelExporter for exporting UltraWebGrid's data. This issue came with v7.2 version of the Infragistics controls.
Please help.
You should report this directly to Developer Support. http://ko.infragistics.com/gethelp/
