165
Vertical or Angled Alignment in ColumnHeader
We are in a situation where we have a large number of columns contained within our XamGrid.
In an attempt to reduce the horizontal real estate, we would like to try either using vertically aligned text (so that the column only needs to be as wide as the height of the text), or to have angled column headers (say between 30 to 45 degrees) so that the Column Header Text is more readable than being completely vertical, but again, the column width can be significantly reduced.
Is this something that is possible within the XamGrid?  If so, how can you go about doing this?
Gary
